Activity Forums Apple Final Cut Pro Legacy Need Quick workflow
  • Need Quick workflow
    Posted by Fred on December 22, 2006 at 1:22 am
    Hey,
    I started mixing a short film project in FCP with audio levels all over the place. I mixed with my peaks set to -6. The Mix is not final and still needs work.
    Now I found out that the max peak is -10. I have to lower all my levels, but I want to bring it into Soundtrack pro for audio tweaking and FX. What’s the easiest way to do this? Should I just export each track as an AIFF audio file and bring that into Soundtrack Pro?
    -THanks.
    Arnie Schlissel replied 19 years, 9 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    December 22, 2006 at 3:47 am
    [FooKai] “I want to bring it into Soundtrack pro for audio tweaking and FX. What’s the easiest way to do this? “
    Select the entire timeline, right click, select Send To>Soundtrack Pro Project
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
