Activity Forums Apple Final Cut Pro Legacy Need project name in browser column
  • Need project name in browser column
    Posted by Colleen Kessler on March 19, 2008 at 12:40 am
    I am setting up a stock library system and am exporting batch lists of stock projects into an excel database. It works remarkably well.
    the only thing that would really make this streamlined is if I could include a column with the Project name in it. isn’t there a way to make a custom column or automate the info into the bin/browser? show source reveals too much info that has to be edited in excel later.
    much thanks.
    Coll
    Colleen Kessler replied 18 years, 5 months ago 4 Members · 5 Replies
  • Jeremy Garchow
    March 19, 2008 at 3:04 am
    What about putting it in the ‘description’ column?
  • Bret Williams
    March 19, 2008 at 4:00 am
    And once you’ve entered it once, just highlight all the clips and right click one, and choose the project name from there and they’ll all change.
  • Zane Barker
    March 19, 2008 at 5:38 am
    [Colleen Kessler] “excel database”
    Just a quick note excel is not a data base program, it is a spreadsheet program. Data base programs are like Microsoft Access, and FileMaker Pro.
    Sorry my dad is just a data base nut and he has pounded this into me.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Jeremy Garchow
    March 19, 2008 at 2:53 pm
    [Zane Barker] “Just a quick note excel is not a data base program, it is a spreadsheet program.”
    Very true, but you can use excel as a ‘backend’ of sorts for FCP projects. I suppose you could use FMP as one as well, but it takes a lot more doing than Excel.
    Jeremy
  • Colleen Kessler
    March 19, 2008 at 5:16 pm
    Viola!!!
    That worked PERFECTLY! Thank you so much!
    and with regard to “database”; sadly I was using that word loosely, I completely agree it is to be a spreadsheet and not a database per se, than you for all your help and insight!
    Colleen
