Activity Forums Zaxwerks need Proanimator help
  • need Proanimator help
    Posted by Dave Fleming on April 5, 2007 at 4:08 pm
    Hello,
    Using Proanimator 4.1.1 stand alone on a mid-level HP8000 PC with 2GB of RAM. I have set up a series of 8 instances of a lower-case “l,” Impact font, in a cylinder wrap. I’m using one of the object style presets that is particularly render-intensive. There’s no camera movement, just the cylinder rotating on the Y axis over 10 seconds. The output with alpha channel will be used as a “set element” to be keyed behind talent in After Effects.
    The problem is that this render is taking approximately 1 frame per minute, and, after two tries, just quits after 15 frames. Can someone tell me why it’s stopping (I’m not there when it happens) and what I can do to decrease render time, if possible?
    Dave
    Matt Rhodes replied 19 years, 5 months ago 2 Members · 1 Reply
  • Matt Rhodes
    April 5, 2007 at 10:44 pm
    Hi Dave.
    I can take a look at your scene if you’d like.
    Feel free to send .aep and media files to: matt@zaxwerks.com
    Matt Rhodes
    Zaxwerks, Inc.
