Activity Forums VEGAS Pro Need post advice on 2 audio voiceover samples
  • Need post advice on 2 audio voiceover samples
    Posted by Nathan Mitchiner on November 12, 2006 at 4:48 pm
    Hello All –
    My company develops custom online and classroom based training (dvds, cds, etc) that oftentimes has recorded voiceovers to go along with the courses.
    We recently got a 4x4ft WhisperRoom Soundbooth enclosure so we can do voiceovers in our office. Our other equipment includes a Mackie 1202vlz pro, AT 3035 mic, M-Audio Delta 44 card, and a PC with Vegasa/Sound Forge to edit.
    I am comfortable with the audio hardware but am VERY NEW (stress VERY) to voice-over post production (EQ, Compression, Reverb, etc). Before I tackle the post, I wanted to get the thoughts from others more experienced on the following 2 raw test VO files that I just recorded this past week. If you all could listen to them and give me any advice on “polishing” and how to move forward I would GREATLY appreciate it.
    https://www.ibiblio.org/nmitch1/ari_brett_vocal_test_edit.wav
    https://www.ibiblio.org/nmitch1/ari_rick_vocal_test_raw_edit.wav
    Thanks ahead of time for helping a novice out.
    Best
    NM
    Nathan Mitchiner replied 19 years, 9 months ago 2 Members · 2 Replies
  • Peter Wright
    November 13, 2006 at 6:16 am
    First of all, I start by thinking the original voice recording is IT. There’s no automatic reason to fiddle with something unless there’s a reason to.
    I thought the first of your examples sounded clearer than the second – not because of the recording, but simply the voice itself.
    Whether I then do anything to the voice depends on things like – what other audio is it to be mixed with (music, ambient sounds etc …) The things I do can range from EQ – dropping off frequencies that clash with other audio, Compressing – can sometimes “strengthen” a voice but not always needed – and a little reverb – important not to overdo this, unless a special effect is required.
    It really comes down to trusting your judgement – does it sound clear, is the speed ok, is it too loud (or soft) – but I know it’s always good to get a second opinion.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Nathan Mitchiner
    November 13, 2006 at 12:45 pm
    Thanks a lot Peter! These VO samples will not be mixed with anything else and are actually going to go out to clients as samples of male talent to choose from for online courses. The first sample is my preferred as well.
    With that said, do you there is a need to actually do anything (EQ, Compression, Normalize, etc) to the first voice at all or should I leave that one as is?
    Would you suggest anything for the second voice as well?
    I just want to make sure that these voice samples sound as polished as possible when cilents listen to them as choices.
    For the record, these samples are from in house co-workers who are non-professionals.
    Thanks Again
    nm
