Activity › Forums › Apple Final Cut Pro Legacy › Need Photoshop/Illustrator Graphic element backgrounds to be transparent for FCP project
  • Need Photoshop/Illustrator Graphic element backgrounds to be transparent for FCP project
    Posted by Jhenion on August 24, 2005 at 6:49 pm
    I want to create some graphics with a transparent background in either photoshop or Illustrator that can then be imported into Final Cut Pro for a video i’m working on. The problem i’m having is that, although I select a ‘transparent canvas’ in photoshop or illustrator, when i save the project and load the graphic in Final Cut the background defaluts to white (thus i can’t show the graphic overlaying a video clip). I’m sure there’s a simple solution to this, but it seem to be entirely beyond me at this point.
    Any help would be greatly appreciated.
    – john
    Tom Wolsky replied 21 years, 1 month ago 2 Members · 1 Reply
  • Tom Wolsky
    August 24, 2005 at 7:03 pm
    Illustrator files need to be rasterized in Photoshop. If you’re saving the file with PSD transparency it should come into FCP without problem. Check its in RGB 8-bit per channel saved on a Mac.
