Activity Forums VEGAS Pro Need one second freeze on several video clips
  • Need one second freeze on several video clips
    Posted by Dave Petteruto on November 23, 2010 at 8:31 pm
    Hello Everyone,
    I have about 100 video clips on the timeline that I need to put a one second freeze on at the start of the clip. Normally I use the velocity envelope for this and do each clip separately. Is there an easier or faster way for me to do this? I’m using Vegas 7 or 9.
    Dave P.
    Dave Petteruto replied 15 years, 10 months ago 3 Members · 3 Replies
  • Jim Greene
    November 24, 2010 at 12:00 am
    You could write a specific script. Otherwise maybe this:
    Place a marker at the beginning of each event. Do thi smanually or Ultimate-S can do this. Then run the ThumbnailAtMarker.js script found here: https://library.creativecow.net/articles/vegas_scripts.html
    Then insert each thumbnail at the beginning of each event. A bit labor intensive, but not so bad with the help of the scripts.
    -Jim.
  • Aleksey Tarasov
    November 24, 2010 at 4:48 am
    Use Copy + Paste Event Attributes technique. Add Velocity to the first event, create a 1 sec freeze then copy event (Edit > Copy). Select all the rest events and apply Edit > Paste Event Attributes.
    Hope this helps.
  • Dave Petteruto
    November 24, 2010 at 5:04 pm
    Thanks Aleksey–that’s exactly what I did and it worked great. Saved me lots of time 🙂
    Dave P.
