Activity › Forums › Apple Final Cut Pro Legacy › need MPEG-2 export for FCP 5.1
  • need MPEG-2 export for FCP 5.1
    Posted by Brad Bussé on March 20, 2007 at 12:57 am
    Hi, can someone tell me where to find the files needed for re-enabling MPEG-2 export from FCP that was removed in version 5? I tried exporting to MPEG-2 from Compressor, but it won’t let me scale to a resolution other than 720×480, and I need 640×448 and 640×512.
    Brad Bussé replied 19 years, 6 months ago 4 Members · 4 Replies
  • Steven Lambion
    March 20, 2007 at 1:45 am
    If you want to buy the component go to http://www.apple.com/quicktime
    if you want to reinstall the component, it’s on the DVD Studio Pro Disk.
    Video Specialist
    Apple Developer
    Owner of GranitWorks
  • Rafael Amador
    March 20, 2007 at 2:25 am
    Hi Saddler,
    The QT MPG2 Export Component will give you even less choices for exporting MPG2 that Compressor. You can only export standard NTSC and PAL. With Cleaner you can set the size of your MPG2 out of those standard.
    Cheers,
    Rafael
  • Bret Williams
    March 20, 2007 at 3:39 am
    Yeah, but for whatever reason it’s much faster.
  • Brad Bussé
    March 20, 2007 at 5:30 pm
    Does anyone here used MegaPEG.X, and do you like it?
