Activity › Forums › Apple Final Cut Pro Legacy › Need More Room For Final Cut Studio 2
Posted by Rp on June 20, 2007 at 11:05 pmI’m trying to install FCP Studio 2 on my HD which is 150 GB’s. I need 40 GB’s to install the entire suite but I only have 25 GB’s free. My systerm folder is 40 GB’s and there is nothing else on the HD. My question is..why am I missing about 100 GB’s. Something is taking up that space but I cant find it. Any solutions?
Gary Alan replied 19 years, 3 months ago 4 Members · 9 Replies -
Russell Lasson
June 20, 2007 at 11:17 pmI’m assuming that you’ve emptied the trash:)
At times like this, Apple+i is my friend. (Apple+Option+i is nice too)
I start by going through the root folder (with Applications, Library, Users, etc) and hitting get info on each one. This will help to figure out where files are hiding. Then you explore more using the for-mentioned key strokes.
You might not need as much as you think because there are probably some old FCP files that the new one will replace. But it’s probably better to just free up the space. Total installation is about 55GB (with everything selected. Everything isn’t selected to by default)
-Russ
Russell Lasson
June 20, 2007 at 11:37 pmIt’s got to be hiding somewhere.
Does the total GBs of Applications + Library + System + Users = Used space on hard drive?
-Russ
Rp
June 20, 2007 at 11:41 pmOk Users is taking up 66 GB’s on my disk! Anyway to tone that down? I only have one user.
Rp
June 20, 2007 at 11:45 pmSo my shared folder under users is taking up 60 GB’s and my own user folder is taking up 70 GB’s. I hope it ok to dump some of this.
Russell Lasson
June 20, 2007 at 11:55 pmYou just need to go through folder by folder to see what’s taking up the space. You could have old render files, 25GB of autosaves, etc, around just taking up space.
-Russ
Rp
June 21, 2007 at 12:01 amGot it. Thanks. This Final Cut Pro looks exactly the same as the last one 🙁
$$$ just to fix the bugs in 5.0.
Ben Holmes
June 21, 2007 at 8:49 amI recommend an excellent (and free) app called “Disk Inventory X”. You can find it here:
https://www.versiontracker.com/dyn/moreinfo/macosx/22694
This scans any hard drive/folder on your system and displays graphically how much space everything is taking up. Extraordinarily useful on a busy laptop hard drive for weeding out forgotten Gb’s of rubbish…
Ben
Editec Broadcast Editing Ltd
EVS & FCP specialists for live broadcast.
OB Server 1 HD – Mobile FCP editing done right.
Gary Alan
June 21, 2007 at 10:50 amRP
Get WhatSize
https://www.id-design.com/software/whatsize/shows instantly all folders and files on a drive anf the size. Largest files in GB are listed first in red. Delete or move to a new drive. empty trash when done.
Gary
