Activity Forums Cinematography Need lighting recommendation
  • Need lighting recommendation
    Posted by Jason Flor on May 23, 2014 at 2:40 am
    Just need a bit of advice for what kind of fixture I need to get the following light output at night.
    The fixture will reproduce the effect of a street lamp above the location area. I need a ground beam spread of about 30 in diameter (with sharp well defined edges) from a fixture that is above the road on a scissor lift about 25-30 ft up. I am working at iso 320 and need an fstop of about f4.
    I take it the HMI’s are more efficient size-wise compared to fresnels?
    What wattage of HMI lamp do you recommend and what kind of volts/ amps do i need as far a a generator goes?
    Post a Message.
    Rich Rubasch replied 12 years, 4 months ago 2 Members · 1 Reply
  • Rich Rubasch
    May 23, 2014 at 4:03 pm
    Sounds like you could also use a Par light used in staging to be able to focus the beam.
    Rich Rubasch
    Tilt Media Inc.
    Video Production, Post, Studio Sound Stage
    Founder/President/Editor/Designer/Animator
    https://www.tiltmedia.com
