Activity Forums VEGAS Pro Need keyboard shortcut for creating space between events in timeline.
  • Need keyboard shortcut for creating space between events in timeline.
    Posted by Mithun Kumar on January 1, 2015 at 6:21 pm
    Hi Need help with sony vegas pro. I need the keyboard shortcut to create space between two events after pressing the keyboard shortcut “S”. Right now i am using mouse but its taking a lot of time.
    This is to cut a movie into pieces and understand how shots are arranged.
    David Eon replied 11 years, 8 months ago 4 Members · 4 Replies
  • Graham Bernard
    January 1, 2015 at 9:09 pm
    Intriguing.
    G
  • Matt Carlson
    January 2, 2015 at 2:41 am
    Off the top of my head I do not know of any keyboard shortcut that adds space. I have, however, added what you needed to my Vegas Black Tools extension. I originally had these options that all can be assigned shortcut keys
    Split Delete Left
    Split Delete Ripple Left
    Split Delete Right
    Split Delete Ripple Right
    After reading your post I added
    Split Add Space
    Split Add Space Ripple
    Send me an email to blackstingproductions@gmail.com if you are still in need of this help and will give you the Black Tools extension.
  • Mithun Kumar
    January 2, 2015 at 4:18 am
    G doesnt work 🙁
  • David Eon
    January 8, 2015 at 4:25 am
    Set a custom keyboard key (under Options dropdown>Customize Keyboard)
    In the search box type Trackview.Nudge.RightByFrames,
    In the Middle box Select Trackview.Nudge.RightByFrames
    In the bottom box type whatever key you want to use to create your space ( I use Trackpad 9 for Right and Trackpad 7 for Left but it’s whatever works for you)
    Click the add button.
    Now you can use that button on your keyboard to move your clip one frame at a time. Or press it as many times as you need to depending on how big of a space you need (30 frames = 1 second). Use the autoripple (Ctrl +L) to nudge the entire rest of the project if you need to.
    I hope that helps. DavidEon
