Activity › Forums › Adobe After Effects › Need it to rain bees
  • Ben G unguren
    February 3, 2012 at 4:28 pm
    If all you have is what’s built-in to AE, I’d suggest the “CC Particle World” effect. You’ll need two layers — one solid that fills the entire screen, and one CUT OUT image of a bee (cut it out in photoshop, or use masks in AE and PRECOMP it). Apply CC Particle World to the solid, then under Particle, set the Particle Type to “Textured Disc”. Again, under Particle, set the Texture to your Bee image. You should see a bunch of bees shooting out of the particle emitter. From here’s it’s just a question of tweaking your settings until you’re happy.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Joshua Mccray
    February 3, 2012 at 8:50 pm
    Thank you for your help – I will try it out this evening. I really appreciate the help
  • Joshua Mccray
    February 4, 2012 at 8:28 am
    It is very close to what I want, but every one of the bees has a yellow disc around it. Still working on it. Now wondering if I can get the rough shape in trapcode … and put a blur on it …
