Activity Forums Adobe Premiere Pro Need help with transcoding
  • Need help with transcoding
    Posted by Paul Thurston on May 18, 2005 at 8:12 pm
    Hi guys,
    I have a small problem and was wondering if maybe some of you have found a way to solve the issue. I have captured via Decklink Pro card a 10 minute video and saved it as JPEG format (high setting.) This sequence ends up being 1.73 GB of data.
    I imported this into the timeline and highlighted it. I went to the Adobe Media encoder so I could save the sequence as a Windows Media Video for streaming. The Preset I
    Paul Thurston replied 21 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • Aanarav Sareen
    May 18, 2005 at 8:16 pm
    Paul,
    Can you export to any other format? (MPG etc) If not, then I would reccomend downloading the encoder’s update from Adobe’s site.
  • Paul Thurston
    May 18, 2005 at 8:34 pm
    Hi Aanarav
    I can transcode when the media was captured as BlackMagic Design 10-bit and 8-bit uncompressed (QuickTime) the transcoding works very well. But as soon as I use any other file format (inside the QuickTime file wrapper), the transcoding fails.
    Could you tell me where I can download the encoder
  • Paul Thurston
    May 18, 2005 at 8:36 pm
    Hi Aanarav
  • Aanarav Sareen
    May 19, 2005 at 12:06 am
    The update can be found over here:
    https://www.mainconcept.com/adobemedia/downloads.html
  • Paul Thurston
    May 19, 2005 at 2:42 am
    Hi Aanarav,
    I noticed that this is not an Adobe website. What will the logical result be of this update to the Premier Pro Media Encoder?
    Regards,
    Paul Thurston
  • Aanarav Sareen
    May 19, 2005 at 3:23 am
    Paul,
    Adobe uses the MainConcept encoder and hence the update is from MainConcept.
  • Paul Thurston
    May 19, 2005 at 3:53 am
    Hi Aanarav,
    Thanks for the information. I downloaded the update. Do you know if there is anything like this for After Effects? I ask because I’ve received the same types of errors when using After Effects 6.5 and Magic Bullet 1.5.
    Regards,
    Paul Thurston
