Activity › Forums › Adobe After Effects › Need help with this Effect .
Posted by Fame Little on January 27, 2006 at 4:24 pmHi All, I
Fame Little replied 20 years, 8 months ago 2 Members · 4 Replies -
Chris Smith
January 27, 2006 at 5:27 pmNeed a lot more detail for a correct answer. How is it framed, what is blocking the effect from happening so far? Etc.
From what you explained all I can say is use a mask to split the screen at the door and put one footage on one side of the mask, and the other on the other side. Shift the clips in the timeline till she looks like she is walking in sync between the shots.
Chris Smith
https://www.sugarfilmproduction.com -
Fame Little
January 27, 2006 at 9:14 pmHi Chris, When you say use a mask to split the screen at the door what kind of mask and how do I split the screen?
Thanks.
Chris Smith
January 27, 2006 at 9:26 pmUse the AE masks. You’ll have to know the very basic fundamentals of AE to work with it. What you are doing very likely is an easy effect but you gotta know the program enough for us to give tips. I’d spend a few days with the manual. You’ll get it.
Chris Smith
