Activity Forums Panasonic Cameras Need help with the VFR function
  • Need help with the VFR function
    Posted by Roli Rivelino on March 5, 2009 at 3:33 pm
    I’m trying to test the VFR function on my HVX 200 and I’ve gone to REC FORMAT and selected 720/25PN, I’ve then gone into SCENE FILE and selected FILM CAM but when I try to go to FRAME RATE it just says default and doesn’t give me any options to change.
    I wasn’t using my firestore at the time;
    I need to know how to adjust the frame rate on the camera first and I guess the firestore as well.
    many thanks.
    Roli Rivelino replied 17 years, 6 months ago 2 Members · 4 Replies
  • Michael Sacci
    March 5, 2009 at 4:08 pm
    Was the default in BLUE?
    If you are going to Firestore you cannot use pN mode, that mode does not go through the firewire port. Use have to use normal P and then VFR setting on the Firestore which removes the redundant frames.
  • Roli Rivelino
    March 5, 2009 at 4:25 pm
    OK thanks, I think I get that as far as the firestore is concerned (still learning!) but as far as the DEFAULT is concerned it’s written in green.
  • Michael Sacci
    March 5, 2009 at 4:28 pm
    You navigate down to the frame rate and press the button in and then all the frame rates are available to scroll up and down then select what you want.
  • Roli Rivelino
    March 5, 2009 at 5:53 pm
    ah thanks, I was being a bit dim there, I expected them all to be laid out in menu form.
    many thanks
