Activity Forums Adobe After Effects need help with shine video wall
  • Hiostt
    September 26, 2005 at 5:03 pm
    Anyone?
  • Hiostt
    September 26, 2005 at 6:41 pm
    Aaarghhh! It won’t shine straight up even if I do backflips in my backyard! It just look like 2D bullshit 🙁
  • Steve Roberts
    September 26, 2005 at 6:50 pm
    To get a shine pointing up in the frame, your source point should be low in the frame.
    Is your boost light turned up?
    Do you have a light source casting a glow in the center, before you apply shine? If you want shine in the middle of the image, your image should be brighter in the middle … if you’re basing your shine on “brightness”.
    Let us know.
    Steve
  • Hiostt
    September 27, 2005 at 12:26 pm
    Yes theres some boost light.
    I have one light center in my “box” so it lights all 5 walls and I have 5 shine’s, one for each wall. In that pic in first post i didn’t have that light yet.
  • Steve Roberts
    September 27, 2005 at 12:48 pm
    Can you send your project to me at ads (at) reidroberts (dot) com?
    (I wrote the address that way to avoid spambots)
    Don’t send footage, just the AEP file.
    Steve
  • Hiostt
    September 27, 2005 at 2:08 pm
    sended
  • Steve Roberts
    September 27, 2005 at 10:46 pm
    I’ve been able to make the shine (not shine 1 or 2) aim upwards by moving the source point down and out of the frame at (360,640). However, that means the effect is radiating from a point outside the frame. If you want that, great.
    Keep in mind that Shine is a “flat” 2D effect: it only radiates outwards in all directions from its source point. It just sees flat video and radiates outward –it can’t see the third dimension. If you want the rays to start from the center of the floor plane and shoot up perpendicular to that plane, Shine can’t do that.
    You might want to look into Lux, a product by Trapcode.
    The most effective way to do this effect is with a real 3D app such as Max, Maya, Lightwave or Cinema4D. The effect is called “volumetric lighting”. At any rate, check out Lux.
    Hope that helps,
    Steve
