Activity Forums Adobe After Effects Need help with SHATTER
  • Need help with SHATTER
    Posted by Steve James on September 7, 2007 at 4:57 am
    Hiya all,
    I have a pic of the front of my house. Can I shatter the EXACT PERIMETER of a window, or door, only ? How do I do that ? Can the ” target-area ” ( for shatter ) be EXACT or just a generalized ” in-the-area ” sort of thing.???
    Many thanks to you all.
    Steve James replied 18 years, 12 months ago 3 Members · 3 Replies
  • Kevin Camp
    September 7, 2007 at 3:25 pm
    duplicate the image in the comp. create a mask shape around the window (with the pen tool)on the duplicate layer. then apply shatter to that masked layer, the effect will only happen on the masked area.
    if you wanted to show something behind the window, copy the mask and paste it onto the lower layer/image. hit ‘m’ to show the mask properties and choose subtract from the mask pulldown. this will knock a hole in that layer.
    now you can place an image/footage/comp behind that layer to reveal what is inside the house, after the window shatters.
    if you notice a slight line around the window, where the masks are effecting the image, you can adjust the mask expansion a little to fill in the gap.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • David Bogie
    September 7, 2007 at 4:28 pm
    I’ve done this dozens of times, it’s great fun. You can tweak the perspective of the Shatter elements with the Shatter camera.
    If you have the money, strongly urge you purchase Total Training’s AE package, any verison since 4.0. His Nibs, Brian Maffittm, spends lots of time on advanced Shatter and the basic funcitons have not changed much. You might find a good deal on an oler used verison of TT’s AE packages. Worth every penny especially if you bill for you AE work.
    bogiesan
  • Steve James
    September 7, 2007 at 6:20 pm
    Thanks guys for your info. I will take it onboard. Much appreciated.
    Thank you.
