Activity Forums Adobe After Effects Need Help with Red Carpet Roll-Out
  • Need Help with Red Carpet Roll-Out
    Posted by Philgold on August 2, 2006 at 2:36 am
    I am doing a red carpet scene and I need to do a red carpet roll out. I would like to find the best way to do this. Any help is apprecited. Thanks in Advance!
    A Gold Production
    Phillip Crook
    Video & Motion Graphics
    phil@agoldproduction.com
    31 Graystone St.
    Warwick, RI 02886
    Philgold replied 20 years, 1 month ago 3 Members · 3 Replies
  • Al
    August 2, 2006 at 8:30 am
    3D
  • Steve Roberts
    August 2, 2006 at 2:11 pm
    In other words, the most realistic way would be to use a real 3D application to crate a rolled-up strip that unrolls itself. There may not be any carpet tutorials. but I’ve seen a “scroll” tutorial somewhere.
    However, you might be able to fake it in AE with three ingredients:
    1: the flat strip of carpet, masked to reveal itself over time
    2: the cylindrical roll, created with the CC cylinder effect, with its position and diameter animated as it rolls along.
    3: the side of the roll, which would be a shrinking circular disk with a sort of spiral pattern on it. The shrinking should probably be a shrinking mask.
    If you can line those guys up and make it work, great. The trick will be working with the cylinder.
    But you know … even this cheat would be easier in a real 3D app. 🙂
  • Philgold
    August 2, 2006 at 2:24 pm
    Perfect, thank you so much, I will try this and let you know what I come up with. Thank you very much.
    A Gold Production
    Phillip Crook
    31 Graystone St.
    Warwick, RI 02886
