Activity Forums Adobe After Effects Need help with ram preview
  • Need help with ram preview
    Posted by Cowgirrrl on December 6, 2005 at 5:04 pm
    although my work area is set to more than 10 sec every time i press ram preview it says:after effects error. u need at least 2 frames to use ram preview.i cnat see anything i set to 2 frames…?
    beginner here, what do i do?
    Denis Shirokov replied 17 years, 3 months ago 3 Members · 2 Replies
  • Jonathan Pitzer
    December 6, 2005 at 7:23 pm
    This usually only happens when you hit the “0” button twice quickly so it cuts itself off. Other than that, try restarting.
  • Denis Shirokov
    June 19, 2009 at 10:13 am
    Go to Edit -> Preferences -> Memory and Cache and make sure that your Maximum Ram Cache size is 60 % or more. It worked for me, had the same problem.
