Activity Forums Adobe After Effects Need help with problematic keing
  • Need help with problematic keing
    Posted by Maxime Marquis on February 8, 2010 at 3:26 pm
    I’m editing a music video that contains a lot of green screen footage to key out. The problematic shots are those of a “human doll” that have yellow hair. No matter what I try, I cannot key out the green without losing opacity in the hair.
    I know, it’s a pretty bad idea to shoot yellow in front of a green screen, but a reshoot is out of question.
    Any tips on how I can get it to work? I use keylight.
    I need help… Thanks
    Serj Bato replied 16 years, 7 months ago 4 Members · 3 Replies
  • Kevin Camp
    February 8, 2010 at 5:24 pm
    keylight also has a feature called ‘inside mask’. it allows you to define the area that it will not key.
    an easy way to create an inside mask is to apply keylight and create a ‘harsh’ key (where you’re not concerned about the edges, just the inside/core matte area).
    once you have that, set the view to ‘intermediate result’ and apply a second instance of keylight. pick the screen color and set the inside mask setting for source alpha to ‘add to inside mask’. that will take the matte form the first keylight effect and use it for a core matte for the second keylight. then you can focus on the edges.
    you can use this in conjunction with aharon rabinowitz’s super tight junk mattes technique, that creates a matte for everything outside the foreground element. then you’re only keying just the edges of the character.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Philippe Lessard
    February 8, 2010 at 7:28 pm
    Maybe you better to do a color correction/removegrain before you key the shot, try to replace the yellow by something else an avoid to change your green, there a couples plugin(BCC) or software(color) to do just that.Then key the shot, use this keyed shot as a track matte over your original shot(the one with yellow hair) and you’re done.Remember the only important color in your shot was the green,since keylight can key any color you just need to have a solid flat background to key, then use this keyed shot as a track matte.You can also divide your shot with different keylight setup(like said before) and/or(for more precise setup)track the problematic region and apply a keylight setup to this portion.I always use those technic on problematics shots and it work great.Also if you didnt have the key correct pro plugins suite, check it out!
    Hope this help
  • Serj Bato
    February 8, 2010 at 8:26 pm
    you can also use color key. using the color picker, pick a specific area on the green screen clicking on ly once. then
    drag the tolerance & feather properties carfully. don’t worry if it’s not properly keyed out, you can duplicated the color key
    and pick another area of the green screen. I’ve tried this before using as many as 6 color keys to do the trick. If this doesn’t
    work well, you have no choice but to animate a garbage matte for the hair as what Mr. Laronde advised.
