Activity › Forums › Apple Final Cut Pro Legacy › Need help with matte key problem
  • Need help with matte key problem
    Posted by Dan Riley on August 16, 2006 at 6:33 pm
    I’ve got a 4 second logo fly-in with a separate moving matte.
    This was created on the Flame.
    Here’s what I’ve done:
    – studio on V1
    – logo fly-in on V2
    – drag the Image Mask filter over logo fly-in clip on V2
    – double click on the V2 clip to get it to the viewer.
    – In the image mask filter, drag the matte clip into the
    mask box.
    The result is, the key is fine, but the matte does not
    move with the fly-in. If I look at it frame by frame,
    the matte is just a still frame of the first frame of
    my matte. How do I get the matte to move with the
    video on V2?
    (I’ve done the above with the Difference Matte filter as well
    with the same results)
    Dan
    Dan Riley replied 20 years, 1 month ago 2 Members · 3 Replies
  • Dan Riley
    August 16, 2006 at 6:45 pm
    Figured it out. I put the fly-in clip on V2, the matte on V3. dropped the
    extract filter on both and adjusted from there. Looks fine.
    Is this they way you all do it?
    Dan
  • Kevin Monahan
    August 16, 2006 at 7:17 pm
    No, I’d have the matte on V2, the fill for the matte on V3 (the logo). Select the V3 clip and choose Modify>Composite Modes>Travel Matte Luma (better to use alpha if there is an alpha channel).
    Check out my book, my good man. 😉
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Dan Riley
    August 16, 2006 at 7:44 pm
    Thanks.
    Dan
