Activity Forums DaVinci Resolve Need help with importing .mts files
  • Need help with importing .mts files
    Posted by Muaz Nikolic on June 23, 2014 at 1:55 pm
    Hello,
    First of all I would like to say that I am new with DaVinci Resolve and I am trying to import some video files but I am not able to see them in Resolve.
    So, I have a few .MTS files that I am trying to edit in Resolve but as I have read here at the forum and also on the official site these files are not supported by DaVinci Resolve 10. After thoroughly research I have found on this link
    howgreenisyourgarden.wordpress.com 2013 11 16 sony-alpha-video-part-2-avchd
    under the section Avoid AVCHD compatibility problems that the solution is to wrapp /transfer files using FFmpeg and SmartFFmpeg into quicktime/.mov files and that after that I will be able to use these files in DaVinci Resolve. So I did that but the result is the same. I cannot see these files in DaVinci.
    My question is what should I do next and where is the problem? Do I need first to set some particularly settings in my project in order to see these files or what should I do? I realy hope that someone will help me about this. Thank you in advance.
    Kerin Sharma replied 12 years, 3 months ago 2 Members · 1 Reply
  • Kerin Sharma
    June 26, 2014 at 6:53 pm
    I had the same problem a couple weeks ago. It was actually the quicktime decoder failing. re-installing resolve and updating my quick time player solved the issue.
    if not try downloading the ffmpeg folder again
    please let me know if this solves the problem or not.
    thanks
    Kerin Sharma
    Colorist|Color Grader
    Web: http://www.sharmakeirn.com
    Email: sharmakerin@gmail.com
