Activity Forums Adobe After Effects Need help with importing JPEG sequence
  • Need help with importing JPEG sequence
    Posted by William Laven on January 31, 2010 at 4:30 am
    I have a camera that makes time-lapse photographs and I’ve been using AE v.5.5 (ancient, I know) successfully for the last few weeks to turn these sequences into QT movies. I do Import>File>JPEG Import as Footage and click the JPEG sequence box. As of date, I’ve made 6 different movies this way – the frames are numbered sequentially, starting at 1 and continuing until, typically, between 1,300 and 1,500 images. Again, no problem until today. I did the exact same thing (many times) with a new sequence, but it only imports frames 1-999. The sequence is 1,440 frames, but it just refuses to Import the entire sequence, always stopping at 999. I’ve checked preferences though find nothing that would seem to effect that and, besides, it has been importing longer sequences without a problem until now.
    What can I do? Is there something to check for that might be creating a sort of Upper-limit on how large a sequence AE will import?
    Walter Soyka replied 16 years, 7 months ago 2 Members · 1 Reply
  • Walter Soyka
    January 31, 2010 at 12:48 pm
    [William Laven] “…it only imports frames 1-999. The sequence is 1,440 frames, but it just refuses to Import the entire sequence, always stopping at 999.”
    It’s been a long time since I’ve used AE 5.5, so this is a wild guess, but do your filenames have enough leading zeroes? In other words, is it Image999.jpg or Image0999.jpg?
    Walter Soyka
