Activity Forums Maxon Cinema 4D Need help with extrude and HDR
  • Need help with extrude and HDR
    Posted by Lasse Ankanpää on June 5, 2009 at 10:36 pm
    Hi all
    Here’s my problem: I created a path in Photoshop, opened it in Cinema, extruded it, and now im trying to add a HDR reflection to it. I created a new material, went to color tab, and placed the HDR texture. Now it shows the HDR in the material sphere. Then i added the material to the Extrude NURBS, and i can only see it on the Extruded part, not in the original path. i added the material on the original path too but it didnt help. Please help! Thanks in advance 🙂
    Pics:
    Lasse Ankanpää replied 17 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    June 5, 2009 at 10:44 pm
    you can’t add a texture to a spline because splines don’t render (not in this case anyway). Probably you don’t see your texture because of the angle to the front face. Try putting some other image in your material that has some bright color (just to see if it is there)
  • Lasse Ankanpää
    June 6, 2009 at 6:59 pm
    Thanks Brian, it worked. I tried a bright violet HDR this time, and the path went violet. Most of my HDR’s are white and big, so i couldn’t see the difference.
