Activity Forums Apple Final Cut Pro Legacy Need HELP with Compressor!!!
  • Need HELP with Compressor!!!
    Posted by Alieninnovation on October 20, 2005 at 7:44 am
    could somebody help me out with FCP or Compressor?
    I need to export footage in a mpeg2 but in Wide 1024 x 576 square pixel Data Rate 6-8 mbit and the sound needs to be in 48 khz Stereo and it should be multiplexed.
    But it all needs to be one file.
    How can I adjust the pixel to square?
    How can I adjust the frame size?
    How can I have it in mpeg-2 as a “.mpeg” format! Not sure in what player it will be played in.
    Also need all this with the multiplexed sound (Footage and Audio in one file)
    I can’t get it to go.
    Help!
    BIG THANKS!!
    iMac G5 17″
    Final Cut Studio
    iMac G5 17″
    Final Cut Studio
    Felix Bueno replied 20 years, 11 months ago 2 Members · 1 Reply
  • Felix Bueno
    October 20, 2005 at 2:18 pm
    Hi
    You can copy any setting and then you can adjust whatever you want. I would do it by this way:
    1. Set In and Out point in your Timeline
    2. Export Using Compressor
    3. Press Presets button and then go to any MPG2 folder (maybe 90 min HighQ Encode)
    4. Copy this setting with the duplicate button (on top-right)
    5. At the bottom you can set all your settings with the Encoder and Geometry labels.
    6. Then apply this setting and run.
    Otherwise you can try to do it in MP4 format. Visit http://www.apple.com/trailers and see the HD features.
    Hope it helps!
    Felix
