Activity Forums Apple Final Cut Pro Legacy Need Help with 4:3 Conversion
  • Need Help with 4:3 Conversion
    Posted by Bensne on December 1, 2005 at 6:58 pm
    I shot a concert in standard definition with the Z1U in squeeze mode. How do I convert the squeezed widescreen footage to a regular 4:3 size in Final Cut 5?
    Bensne replied 20 years, 9 months ago 2 Members · 2 Replies
  • Ben Insler
    December 1, 2005 at 7:22 pm
    I haven’t shot with squeezed in a long time, but if I remember correctly final cut will understand the difference between your caputred 16×9 footage shot with a 1.2 pixel aspect ratio and your 4×3 0.9 pixel aspect ratio sequence. It should automatically maintain the 16×9 nature of the footage with a letterbox when you place it in your 4×3 sequence, although you may need to render for both previewing for editing purposes and exporting to tape at full quality.
    best,
    Ben
  • Bensne
    December 3, 2005 at 4:10 pm
    Unforntunately, it doesn’t work in the way you described. Thanks for the response, but does anyone else have any other suggestions???
