Activity Forums Adobe Premiere Pro Need help using motion on Premiere Pro
  • Need help using motion on Premiere Pro
    Posted by Gwailodragon on October 18, 2006 at 6:07 pm
    Hi there,
    This may seem like a simple question but……I’m making a documentary and I’m using archive images and need to be able to zoom into them. The last version of Premiere I had was Premiere 5 and it was easy to do on ‘motion’ on that, because there was an option to just drag the image where you wanted it to go. I’ve now got Premiere Pro and I can’t work out how to do it on this!
    Any help would be very much appreciated!
    Thanks very much
    Peter
    Steven L. gotz replied 19 years, 11 months ago 3 Members · 2 Replies
  • Blast1
    October 18, 2006 at 7:53 pm
    Click on the object on the timeline to select it, select the Effects Control tab above the source monitor and the motion controls will be there
  • Steven L. gotz
    October 18, 2006 at 11:42 pm
    Once you click on it in the sequence, you should be able to move it around with a mouse right in the program monitor.
    Steven
    https://www.stevengotz.com
