Activity › Forums › Apple Final Cut Pro Legacy › need help urgenty
  • need help urgenty
    Posted by Niti Shah on May 4, 2005 at 5:00 am
    Hi
    I am facing some weird problem using media manager. I have followed all the instructions available on the net regarding media manager. I am doing offline cut on one machine and want to do online on other (both FCPs). I used media manager
    Jerry Hofmann replied 21 years, 5 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    May 4, 2005 at 11:24 am
    Media Manager and Speed changed clips don’t get along. It’s buggy fur sure.. FCP 5 will be addressing this I hear…
    HOWEVER… the only real way to get around this is to “unspeed” your clips before MM, add the extra video if they were sped up… then use MM, and re speed change the clips in the online session.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
