Activity › Forums › Compression Techniques › Need help! Static problem with Compressor and MPEG 4
  • Need help! Static problem with Compressor and MPEG 4
    Posted by Peter Dewit on December 14, 2006 at 3:29 pm
    k I’m trying to create so fairly small(about 10 meg) MPEG 4 files from clips between 30 sec – 2 min long. Right now I’m using compressor’s MPEG 4 setting the current settings in compressor are:
    320×240
    1000 kbps
    Frame control: Off
    No Cropping
    Pixel Aspect ratio default
    There are currently no filters on the video in FCP. The source video is 8-Bit uncompressed. When i render the file sie comes out ok but there’s alot of noise in the video especially when there’s movement. Any ideas how I could set it up to get crisper looking video within these parameters?
    Peter Dewit replied 19 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
