Activity Forums Adobe After Effects NEED HELP SOON-Giant files
  • NEED HELP SOON-Giant files
    Posted by Moviemaker2727 on June 28, 2007 at 12:55 am
    I just finsihed a sixty secon movie in premeire pro with about 20 seconds worth of shots from AE, the file is so huge i cannot put it on youtube or email it or anything, what can i do to make it smaller? I reder things in ae by making a prerender composition and then rendering. I dont have to much time to go back and re render anything but if i must i must. I NEED THIS VIDEO ON THE INTERNET BY 7 AM EASTERN TIME ON SATURDAY
    Scott Roberts replied 19 years, 3 months ago 3 Members · 2 Replies
  • Clint Lemaire
    June 28, 2007 at 3:36 am
    What CODEC did you use when you rendered the file? Seems like you used a lossless CODEC, which will give you a huge file not sutable for the web.
  • Scott Roberts
    June 28, 2007 at 4:00 am
    Try rendering out a Quicktime Sorenson 3 clip from Premiere – great codec for retaining color and quality, while compressing the video down. Depending on how small you need to make the file size, you can cut the frames per second in half, reduce the dimensions of your final video, etc. Lots of things to make the video smaller.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
