Activity Forums Apple OS X Need Help Setting Up Mirrored RAID in OSX!!!
  • Need Help Setting Up Mirrored RAID in OSX!!!
    Posted by Jordan Livingston on September 22, 2006 at 6:30 pm
    Dear Creative Cow Members,
    I currently own a LaCie Bigger Disk Extreme 2TB external harddrive, which is almost full with data from archived video editing projects. I would like to purchase a second identical drive and set them up as a Mirrored RAID using OSX’s Disk Utility. My thinking is that this configuration will provide me with an automatic, real-time backup of my data. I have a few critical questions:
    1.) When I set up the Mirrored RAID using Disk Utility, will my existing 2TB of data be erased? If yes, how can I avoid this?
    2.) How does the 2TB of data from my existing drive find its way onto the new, additional drive in the Mirrored RAID?
    3.) What block size should I use?
    4.) Should I use the “Automatic Repair” feature, or is that only applicable if I designate a third, “spare” disc?
    Thanks very much in advance for the answers to these questions – I sincerely appreciate your help!
    – Jordan
    13 replied 20 years ago 2 Members · 1 Reply
  • 13 Create COW Profile Image
    13
    September 23, 2006 at 3:43 am
    “will my existing 2TB of data be erased”
    – Yes your existing data will be erased,
    “If yes, how can I avoid this?”
    – buy 2 new drives and mirror rade them
    “How does the 2TB of data from my existing drive find its way onto the new, additional drive in the Mirrored RAID?”
    – You copy it onto the new mirrored raid
