Need Help Please
Posted by Don Dulmage on July 18, 2006 at 8:04 pmBefore I throw my entire system in the trash and switch to FCP I am going to try one more time to get this up and running.
Media 100i ver 8.1.1 running on a G4 Dual 500 1MB Ram, OSX 10.2.8
Old programs are running fine most of the time. But any new work I try to digitize and edit will result in the system freezing up and I get one of the following error messages.
“Some reel time errors occurred where there are no items to render. Check your systems performance.”
“Could not play because the video data format is invalid”
“Could not play because the media was recorded with a newer version of Media 100i”
I have done all of the usual repairs such as dumping perferences, verifying permissions and running all the tests with Disk Warrior and Tech Tool Pro 4. Is there anything else I can do, or is the system just to old to repair?
Thanks for you help.
Don
Jim Calahan replied 20 years, 2 months ago 7 Members · 13 Replies -
Floh Peters
July 18, 2006 at 9:09 pm[Don Dulmage] “Media 100i ver 8.1.1 running on a G4 Dual 500 1MB Ram, OSX 10.2.8”
I hope you mean 1GB of Ram. G4 Dual500 and 1GB Ram is really a low end configuration for running Media 100 on OSX (or running any professional application on OSX).
The main question is where your crashes come from. To me it most likely sounds like a hardware problem; probably related to the Media drives you are digitizing to. What kind of drives and controller do you use? Have you tried the newest firmware and drivers for everything? Have you defragmented your media drive? Have you tried digitizing to your boot drive in a low data rate to see if the problem happens also? Are your Media 100 boards (and storage connection boards) located as suggested in the CPG for your system configuration?
Floh
Don Dulmage
July 18, 2006 at 11:16 pmFlo,
Thanks for the respond. Yes, I ment 1GB, which has seemed to be enough in the past.
I am using a ATTO Express PCI UL3D controller with 5 – Segate 75GB SCSI drives. I updated all the firmware and drivers about a year ago. The drives have all been defraged. I have tried going direct to a internal drive and also to external firewire drives. Nothing is working. In the past I have been able to run a 300KB diret to the firewire drives, but not any more. However, I can run some older shows I have stored on the firewire drives without any problems.
The Media 100board and SCSI card are in the proper slots acording to my VAR.
Slot A – Displey ATY 128 Pd 5046
B – Media 100 – P6000
C – Displey ATY Raeon p 5144
D = SCSI 2 ATT) UL3DDon
Floh Peters
July 19, 2006 at 7:54 amDon,
yes, your cards seem to be in the right order. If you have some time to troubleshoot I would suggest removing both the additional graphics card as well as the SCSI card, reset PRAM on startup (press CMD-ALT-P-R until you hear a second startup chime) and run the Media 100 test application after this. If the test passes then open Media 100 and try to digitize on your internal or FireWire drive. If this works I would put back in the additional Graphics card to see if the system still works then.
Bruce Mcpherson
July 19, 2006 at 10:04 amAlso when you run the M100 test, click on “loop” and retire to bed. Next morning it should show 100 test passes if all is well, and believe me if it passes 100 tests, all is well.
I had a dual 500 on ver 7 and it ran quite fine, but the change to v8 seemed to bog it down somewhat and the change to a dual 1gig g4 sorted this out, you should pick one of these up off ebay (for example item number: 330008831602) for under $300
I have noticed that sometimes as the computers age, the heat transfer grease arround the proccesser hardens and I suspect causes intermittants. get it reseated and new silver heat grease applied.
All the best
Bruce Mc
Victor Tsikouris
July 19, 2006 at 6:26 pmI had the same problem you are having now, used media 100 support with no luck, good people though- try this first, put your media files on another drive, I reccomend at least a firewire drive, make sure media 100 reads these files on the time line, if it plays through fine several times the old drive is going bad, if you are still getting these errors try this next step- go to your quicktime folder in your library throw out all media 100 codecs, uninstall media 100 then reinstall media 100, redigitze your files from this project your drivers may have become corrupted. I did this step with the firewire and all was well, however when the files went back on the medea drive the errors came back, used a second scsi card and new cable and still had problems, firewire files worked well, sent medea drive in and it passed all tests good people also-, was about to throw out computer (g-4mirrored doors) but had a job to do switched to sata card and mac gurus raid and it is working well.
Al J. marschke
July 21, 2006 at 12:39 pm[Floh] “Have you defragmented your media drive?”
Is that really a good idea. Defraging a media drive on a Media 100 video drive can lose everything?
Al J. Marschke
BluMars Media
Pittsburgh, PA -
Floh Peters
July 21, 2006 at 1:18 pm[Al J. Marschke] “Is that really a good idea. Defraging a media drive on a Media 100 video drive can lose everything?”
Um, even rturning on the computer can destroy your hard drives, but it is highly unlikely. If you defrag your media drives with a tool that is developed for the OS you are using there is no reason why defragmenting a drive should do any harm.
Al J. marschke
July 21, 2006 at 8:54 pmYou can defrag the 844 PC. But last I heard it’s a no no to defrag a Mac Media 100. Unless that changed in the newer versions.
Al J. Marschke
BluMars Media
Pittsburgh, PA -
Floh Peters
July 21, 2006 at 10:50 pm[Al J. Marschke] “You can defrag the 844 PC. But last I heard it’s a no no to defrag a Mac Media 100.”
I never heard that, and I don
