Activity Forums Adobe After Effects Expressions Need help in moving the comma
  • Need help in moving the comma
    Posted by Avinash Ramanath on February 1, 2021 at 6:18 pm
    Hi, I came across this incredible number counter, I need help in moving the comma one place left. For example, currently, it’s like this 400,00. I want it to be 40,000.
    numDecimals = 0;
    commas = true;
    dollarSign = false;
    beginCount = 500;
    endCount = 40000;
    dur = 2;
    t = time - inPoint;
    s = ease (t, 0, dur, beginCount, endCount).toFixed(numDecimals) + "+";
    prefix = "";
    if (s[0] == "-"){
    prefix = "-";
    s = s.substr(1);
    if(dollarSign) prefix += "$";
    if (commas){
    decimals = "";
    if (numDecimals > 0){
    decimals = s.substr(-(numDecimals + 1));
    s = s.substr(0,s.length - (numDecimals + 1));
    outStr = s.substr(-s.length, (s.length-1)%3 +1);
    for (i = Math.floor((s.length-1)/3); i > 0; i--){
    outStr += "," + s.substr(-i*3,3);
    prefix + outStr + decimals;
    }else{
    prefix + s;
    Kevin Camp replied 5 years, 7 months ago 3 Members · 4 Replies
  • Trent Armstrong
    February 1, 2021 at 6:42 pm
    Hi!
    The expression is adding a “+” to the end of the number and therefore putting the comma in the wrong spot.
    Try this line instead:
    s = ease (t, 0, dur, beginCount, endCount).toFixed(numDecimals);
    And let me know if that’s just not what you’re looking for.
    Trent
  • Avinash Ramanath
    February 16, 2021 at 12:05 pm
    Hi Trent, thanks for your reply and direction.
    I found a better way and shorter of doing it. Leaving the code here for someone who might find it useful,
    Thanks to Nick Khoo’s video –
    https://www.youtube.com/watch?v=j3HftxMxbfs&t=564s&ab_channel=NickKhoo
    Apply point control effect to the text layer and paste the below expression to sourceText param.
    s = "" + Math.round(effect("Point Control")("Point")[0]);
    "INR " + s.replace(/\B(?=(?:(\d\d)+(\d)(?!\d))+(?!\d))/g, ',') + "+";
    //use this for numbers with decimals
  • Trent Armstrong
    February 16, 2021 at 1:53 pm
    REGEX! Right on! This is a great look at how regex can be used in expressions!
    Trent
  • Kevin Camp
    February 16, 2021 at 5:06 pm
    Also, if you have a newer version of AE (17+) and set the Expression Engine to JavaScript in the Project Settings, you can use the java function toLocaleString() to add commas/separators based on language and country.
    This would put in commas as separators:
    num = effect("Point Control")("Point")[0] ;
    num.toLocaleString('en-US') ;
    This would use spaces for French:
    num.toLocaleString('fr-FR') ;
    You can use a slider or rotation control or even the sourceText value, but you’ll need to convert it to float or integer first:
    num = effect("Slider Control")("Slider") ;
    parseFloat(num).toLocaleString() ;
    There are also options for currency and date and more in toLocaleString(). This link has some examples: https://www.c-sharpcorner.com/article/format-number-currency-and-date-using-tolocalestring-method-in-javascript/
