Activity Forums Avid Media Composer Need Help! Hi rez error.
  • Need Help! Hi rez error.
    Posted by M.jones 20 on September 22, 2006 at 10:41 pm
    I batch captured a huge sequence an High resolution 1:1,
    And then my timeline won’t play!!
    the error message is:
    MAXIMUM PLAY STREAM EXCEEDED.
    I’m in a pinch, can anyone help! I know it’s friday, but I have a deadline!
    your help is appreciated.
    Michael Hancock replied 19 years, 12 months ago 3 Members · 6 Replies
  • Michael Hancock
    September 22, 2006 at 11:16 pm
    Do you have effects that aren’t rendered? If so, render them, even if they’re supposed to be realtime. I assume you’re on a Mojo? You’re limited to 2 streams of 1:1 on a Mojo, I believe. Any more than that and you have to render any effects, or possibly do a mixdown of the entire sequence so you have only one stream of 1:1.
    Mike.
  • M.jones 20
    September 22, 2006 at 11:22 pm
    Yes, I’m on a MOJO.
    I’ll try it and let you know!
    Thanks for replying to me on a friday evening.
    I’ll be in touch.
  • Don Logan
    September 24, 2006 at 5:50 pm
    Also, When you say huge…how long. You cant play a clip/sequence longer than 3 hours with a Mojo.
  • Michael Hancock
    September 24, 2006 at 10:08 pm
    Is there really a 3 hours limit with Mojo? What happens after 3 hours? Does it just shut down, or quit playing? Odd…I didn’t know that. Then again, I don’t cut 3 hour programs.
    Mike.
  • Don Logan
    September 25, 2006 at 6:56 pm
    3 hour with a Mojo
    6 hour with adrenaline hardware.
    After the 3 hour is up it shows up as media offline and will not play the remaining.
    Anything longer than a 3 hour clip is near unmanagable IMHO.
  • Michael Hancock
    September 25, 2006 at 7:10 pm
    Interesting! I agree with you…anything close to 3 hours is way too long unless you’re cutting the next epic film of the generation, and even then 3 hours is pushing it.
    Mike.
