Activity › Forums › Apple Final Cut Pro Legacy › Need Help: HDV 1080i/50 capture with Lumiere HD sound out of sync
  • Need Help: HDV 1080i/50 capture with Lumiere HD sound out of sync
    Posted by Clemens on April 16, 2005 at 9:24 pm
    Using Lumiere HD for capturing HDV footage shot with Sony Z1 @1080 50i worked fine. Also demultiplexing was no problem. But when I tried do convert the footage for importing to FCp there was no setup for 50i only for 60i DVCProHD. So I tried working with this setup but changed the fps setting to 25. The clips play back correctly but the sound is out of sync. Any idea what to do? Thanks in advance
    Clemens
    Clemens replied 21 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
