Activity Forums Adobe After Effects need help for “fast previews” settings
  • need help for “fast previews” settings
    Posted by Thomas Hansen on February 17, 2009 at 7:34 am
    Hello 🙂
    Anyone that can help me with the fast preview settings.
    Everytime I try to preview something in AE that has a bit effects in it, it is allmost impossible to preview because its taking to long time just to preview 2 or 3 frames, so its hard to work on anything when I cant watch all the details.
    got 4gb ram ( though it says that I have 2,93gb ), 512mb 1950series from ATI, and a intel dual core 6600 ” 2.40GHz
    Thx
    Colin Fuller replied 14 years, 6 months ago 4 Members · 3 Replies
  • Kevin Camp
    February 17, 2009 at 9:30 pm
    here are some ways to speed up previews:
    1. reduce the preview resolution with the down sample pop up at the bottom of the preview window (it normally says full, try a lower setting to speed things up).
    2. right next to the down sample pop up is a feature called region of interest. use it to create a rectangle around a portion of the frame that you are focusing. this will preview just that area and thus reduce render time.
    3. use the ‘skip’ setting in the time controls panel (window>time controls) to tell ae to skip frames as it renders previews… your preview will be jerkier, but it will render a longer sequence faster.
    4. disable motion blur and frame blending for previews by toggling their icons in the time line.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Sam Turner
    February 16, 2010 at 4:49 pm
    Dave = rude
  • Colin Fuller
    March 13, 2012 at 6:36 am
    yes, if the computer becomes too hot.
    and the fast settings are for quick previews, if you want to see, for example, if the video syncs to the music
