Activity › Forums › Apple Final Cut Pro Legacy › need help fast
need help fast
Posted by Adair Simon on October 2, 2008 at 10:46 amExported a QT file that has great video and audio in FCP to DVDSP. When it gets to DVDSP it doesn’t have the audio. In FCP I have an imported aif file that sometimes adds a third audio track and sounds fine. What am I doing wrong in exporting?
Adair
Adair Simon replied 17 years, 11 months ago 6 Members · 9 Replies -
Walter Biscardi
October 2, 2008 at 10:50 amYou can’t bring a quicktime into DVDSP. You need to bring in an MPEG-2 and AC-3 file.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Adair Simon
October 2, 2008 at 11:58 amI often choose the export to QT or QT Conversion if the project is under 1 hour 45 min and then import it into DVDSP with good results. And DVDSP accepted it – just no audio this time. So I am a bit confused.
Also – Is there a way I can compress one sequence in FCP while working on another sequence?
Adair
Andy Mees
October 2, 2008 at 12:01 pm(Actually you can, Walter. DVDSP is quite capable of accepting a QT movie file and doing the compression itself.)
Walter Biscardi
October 2, 2008 at 12:31 pm[Andy Mees] “(Actually you can, Walter. DVDSP is quite capable of accepting a QT movie file and doing the compression itself.)”
Yeah, I forgot they brought that in from iDVD. We never do that and I would never recommend that as it’s better to have more control over your finished product.
Jason Porthouse
October 2, 2008 at 2:24 pm[walter biscardi] “We never do that and I would never recommend that as it’s better to have more control over your finished product. “
I totally agree re the control – but , FWIW, for client approvals (not quallity critical, say for a version cut) it’s a much faster way of knocking out a DVD… took me about half the time than the FCP-Compressor-DVDSP route, and the encoding looked OK. Will be doing it again…
Jason
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
Tom Wolsky
October 2, 2008 at 2:43 pmGetting back to your problem, does the exported file (I’m assuming you’re exporting to QuickTime Movie) have audio in it? Did you mixdown the audio before you exported?
BTW, what versions of FCP, DVDSP, OS, and QT are you using? Things change and don’t always work the same for all versions. Be specific.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Adair Simon
October 2, 2008 at 5:25 pmI’m using FCP 6 Bundle with DVDSP and QT 7. I did not mix down the audio before I exported it, but I often don’t mix down the audio and the audio always (except this time) shows up well and sounds fine.
I sent the project to compressor about 10 AM and it is still compressing. I have another project in FCP that I need to edit, but while compressor is compressing I cannot continue to edit. Is there a way that I can work on another FCP project while that is compressing?
I do appreciate all the help.
Adair
Gsp
October 2, 2008 at 8:12 pmMake a QT Ref movie out of FCP then take THAT file into compressor. That will free up your FCP.
Be sure to UNCHECK the option that says “make movie self contained”
Adair Simon
October 2, 2008 at 8:39 pmThank you. That will really help not tying FCP up to compress.
I finally got the project compressed and put it into DVDSP and it worked. Thank you all for your help and advice. I will be able to get this to the client.
Thanks again.
Adair
