Activity Forums VEGAS Pro Need help FAST: Using PowerPoint in Vegas
  • Need help FAST: Using PowerPoint in Vegas
    Posted by Swfproductions on September 14, 2006 at 4:30 pm
    I’m wondering if there’s any way to import PowerPoint documents into Vegas 6.0. I don’t have PowerPoint on my computer; rather I have a presentation that someone wants me to incorporate. Do I need to buy PowerPoint to be able to do this, or is there a way around it? And is it possible to lift finished PowerPoint slides and bring them directly into my project media/timeline?
    Thanks for any advice.
    Michael O’connor replied 20 years ago 5 Members · 6 Replies
  • Lee Mceachern
    September 14, 2006 at 6:30 pm
    I don’t know the answer to your question but I can offer this: If you decide to get PowerPoint, it has a “Save” function, just like any other program. When you have a PPT presentaton active and select File>Save, it will ask you if you want to save just one slide or the entire set. And it will also give you the option of saving them in other formats, e.g. jpegs. You can select such a file that will allow you to import to Vegas. Beware: some PPT slides import very nicely to video but some, because of tiny text or thin horizontal lines or violation of NTSC colors or title safe, etc. might require you to take your exported files into Photoshop to “adjust” them.
    Good luck.
  • Edward Troxel
    September 14, 2006 at 7:14 pm
    Since you don’t have PowerPoint, do you have the PowerPoint player? If yes, just run Camtasia and capture the screen as it plays.
    Edward Troxel
    JETDV Scripts
  • Terry Esslinger
    September 15, 2006 at 11:51 pm
  • Michael O’connor
    September 19, 2006 at 1:53 pm
    JeditDV; What is Camtasia? What does it do and where is it available? Would it work with Vegas 4. Thanks.
  • Edward Troxel
    September 19, 2006 at 2:57 pm
    Camtasia is a screen recorder by TechSmith. https://www.techsmith.com/camtasia.asp
    It will capture whatever is happening on the screen. That’s how many computer tutorials are created. The files created by Camtasia can then be loaded into your NLE.
    Edward Troxel
    JETDV Scripts
  • Michael O’connor
    September 20, 2006 at 3:33 pm
    Cool! Thanks.
