Activity Forums Adobe After Effects [NEED HELP] eliminate Timelaps flickering ???
  • [NEED HELP] eliminate Timelaps flickering ???
    Posted by Ruediger Meier on September 22, 2006 at 9:28 am
    I shot some timelapse with a digital photo camera. Everything was set to manual an I use some lamps for same lighting conditions but the pictures are a little different in level/brightness. If I play this timelapse, it has a flickering – some more, some not.
    How can I eliminate (or reduce) this flicker? Any ideas or tutorials?
    Thanks for any help!
    Ruediger
    Ruediger Meier replied 19 years, 11 months ago 3 Members · 3 Replies
  • Studiobeneden
    September 22, 2006 at 10:09 am
    try using the Color Stabiliser
    goodluck
  • Mylenium
    September 22, 2006 at 11:32 am
    Use the Auto Contrast/ Auto Brightness/ Auto Color filters. Just make sure you give them enough look-ahead frames.
    Mylenium
    [Pour Myl
  • Ruediger Meier
    September 22, 2006 at 4:23 pm
    Thanks! Will try it and post my experiences here a little later. Any other suggestions or a PlugIn? I want to try Film Fix from red giant ( https://www.redgiantsoftware.com/filmfix.html ) but the installer can
