Activity Forums Apple Final Cut Pro Legacy Need help desperately
  • Need help desperately
    Posted by Niti Shah on September 13, 2005 at 12:34 pm
    Hi
    I am having major problems using motion and dissolve effect with DV-PAL footage. Wherever I am using motion effect (in DV_PAL timeline setting) it shows me green bar above suggesting preview quality and gives me poor video quality. And if I render, it gives me jittery play back.
    If I keep timeline setting to Targacine Pal-YUV. When I use motion effect and dissolve together. I get jerky dissolve and jittery motion play back. And doesn
    Niti Shah replied 21 years ago 3 Members · 3 Replies
  • Walter Biscardi
    September 13, 2005 at 1:38 pm
    Sounds like the field order is reversed in your Sequence or in your captured clips. For Pal I believe the field order should be Upper (Odd) Field First.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Per Rönnecke
    September 13, 2005 at 3:01 pm
    [Walter Biscardi] “For Pal I believe the field order should be Upper (Odd) Field First.”
    For DV-Pal it should be Lower (even).
    /Per
  • Niti Shah
    September 14, 2005 at 4:26 am
    i have tried changing sequence settings to upper odd and lower even, it dident work. i dont know how to change it in capture settings. still leaving with the same problem. please help
    thanks
    nikei
