Activity › Forums › Apple Final Cut Pro Legacy › NEED HELP! DeckLink HD Extreme and FCS (Leopard)
Posted by Paulius Zavadskis on November 11, 2007 at 1:51 amAfter installing DeckLink 6.6.1 codec, FCS don’t want work. It even won’t start program. There is something that it didn’t see my card.
Jozsef Pinter replied 18 years, 9 months ago 6 Members · 11 Replies -
Roddy Jamieson
November 11, 2007 at 12:33 pmDid you uninstall the previous drivers before installing 6.6.1? Remember that you lose all your settings so check the control panel and reset all you FCP settings. I have just installed and it works perfectly.
Roddy Jamieson
Paulius Zavadskis
November 11, 2007 at 2:57 pmI did “clean” instal of Leopard. After installing FCS, everything is fine. But after DeckLink 6.6.1 codec, it don’t work…………….. there is the message “Final Cut Pro recommends that youe system have a Quartz Extreme capable video card”
Zak Mussig
November 12, 2007 at 9:08 pmIs this FSC 1 or 2? Also, do you have video desktop enabled in system preferences? I’m wondering if your DL card is your “unsupported” video card.
I followed the same process as you (with FCS2) and my system is just peachy, so I’m just trying to eliminate a couple of possibilities.
Zak
Paulius Zavadskis
November 12, 2007 at 9:28 pmIt’s FCS 2. I have DeckLink HD Extreme.
“do you have video desktop enabled in system preferences?” ____? how to check it? -
Zak Mussig
November 12, 2007 at 9:41 pmGo to the DeckLink preference pane in System Preferences and see if the “Enable Video Desktop” box is checked.
Zak
Paulius Zavadskis
November 13, 2007 at 1:05 amThe same – FCS didn’t load… I try today DeckLink Extreme (not DeckLink HD Extreme) – the same…. AAE starts perfectly, FCS, Color – no….
I am a freelance film/comercials editor director.
Zak Mussig
November 13, 2007 at 2:34 pmDo either of you have anything else installed on our machine besides the OS, FCS, Adobe Apps (video apps don’t work under Leopard right now… PS and Illustrator are fine), DeckLink driver, and maybe some misc. drag ‘n drop software?
My system is a Mac Pro with Leopard, FCS2, with Decklink driver 6.6 and it’s been working like gangbusters. Is it luck of the draw, or are your setups different? Did either of you use the migration assistant to bring over old files and settings after installing Leopard? That killed mine and I had to reinstall Leopard and FCS.
Zak
Jozsef Pinter
November 16, 2007 at 9:57 pmHi!
We just got a Mac Pro Quad with Nvidia Quadro Fx 4500. Brand new Leopard install form the drop in DVD. FCS2 install worked fine. Multibridge Pro was taken into slot 4, and the system mixed up the video card with the Decklink. Final Cut gave the message that we need to use a Quartz Extreme capable video card. Multibridge Pro only works in slot4, but the same message is given in all the time we put the Decklink card into the right slot.
Do you have any idea?
Thx!
J -
Gary Adcock
November 17, 2007 at 6:59 pm[jozsefpinter] “FCS2 install worked fine. Multibridge Pro was taken into slot 4, and the system mixed up the video card with the Decklink. Final Cut gave the message that we need to use a Quartz Extreme capable video card. Multibridge Pro only works in slot4, but the same message is given in all the time we put the Decklink card into the right slot.
“try switching the DVI connection to your COMPUTER monitor to the other DVI connection on the graphics card reboot-
AH we see the BMD drivers work with leopard— yeah
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflowshttps://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
