Activity › Forums › Blackmagic Cameras › Need help deciding what camera to buy
Posted by Mike Lavin on July 20, 2013 at 7:01 pmIm on the fence about which camera to buy and wanted to know what the pros and cons are for the black magic camera. I can’t decide between the black magic and the Sony nex vg 900 and would like advice on which one would be a better buy. I plan on filming music videos and tv programming.
Richard Martz replied 12 years, 8 months ago 3 Members · 4 Replies -
David C jones
July 23, 2013 at 6:34 pmIn my opinion, the BMCC is really more of a professional production camera. The BMCC records internally in ProRes 442HQ and RAW uncompressed; the two highest quality codecs available. The Sony nex vg 900 has internal compression rate is 28Mbps though, you can run uncompressed 1080p out via the HDMI output.
In ether case, be prepared to spend money on all the extras you’ll need or want; case, lenses & light control, like filters, mattebox, flag; batteries, mounts and/or cages, especially with the BMCC.
Dave J
Mike Lavin
July 23, 2013 at 7:42 pmThank you for your input, in the last couple days I have decided on the BMCC as my next camera. Do you have any advice as far as stedicam, external battery, and external memory goes?? I would really appreciate the advice.
David C jones
July 23, 2013 at 9:06 pmI have this battery mount from View Factor https://www.viewfactor.net/products/blackmagic/bmc-ab-power-hinge.html. And during my last shoot with the BMCC used their cage, rods and top handle along with the Redrock Mattebox & follow focus (Redrock also makes all or most of the other items, too).
As far as memory I used the SandDisk Extreme SSD 480GB.
You’ll also want to get an external monitor; the one on the back of the BMCC is almost useless as a field monitor; it’s VERY reflective and somewhat dark).
On thing to note about the BMCC: it doesn’t have any built-in filters like neutral density so, you’ll want to buy or rent a set if you’re doing anything outside.
Dave J
Richard Martz
December 15, 2013 at 12:18 amIf you have not found a battery system yet, check out this one from BrikPower: https://www.ebay.com/itm/221337096470?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
I developed the battery and it is incredible. One battery will last WHILE RECORDING with viewfinder at 100% will last for 4 hours. And they are mounted in a cast aluminum case – NO PLASTIC.
Our BRIKPOWER Battery comes with one, 3 foot long BMCC power cable AND a 12 foot extension cable to place the battery power somewhere other than at the camera head (using a teleprompter or placing the BMCC on a jib arm).
I’m a Cinematographer. When I began to investigate what battery I wanted to use with my own BMCC camera I discovered that I wanted more from my battery. Our battery is intended to be mounted behind and below the camera for an unobstructed view of the BMCC viewfinder. BRIKPOWER is tough. We skimped on nothing. This battery system is ready to be mounted on 15mm rails and comes with TWO integrated Aluminum rail blocks for that purpose. Having dual rail blocks distributes the battery weight with 4 locking points so that the battery is secure. Each battery has it’s own set of rail blocks so changing the battery is a fast, painless process.
BRIKPOWER – Battery Power for Blackmagic Cinema Camera.
CAST ALUMINUM HOUSING 3″ x 4″ x 5.5″ to fit perfectly with a rail mount
15mm RAIL BLOCKS FOR MOUNTING ON CINEMA RAILS ARE INCLUDED
LED INDICATOR LIGHT AND DISCONNECT SWITCH
LASTS UP TO 4 HOURS WITH BMCC
3′ BMCC CABLE AND A 12′ EXTENSION CABLE ARE INCLUDED
DESIGNED specifically TO WORK WITH BMCC
FCP 7
FCP X
ADOBE CREATIVE SUITE CC
MAC 8 core
After Effects
PhotoShop
Illustrator
Lots of other Fun Stuff!
