Activity Forums Adobe Premiere Pro Need help capturing with DVStorm2 Pro
  • Need help capturing with DVStorm2 Pro
    Posted by Kurt Raihn on April 5, 2005 at 1:15 am
    Hey people,
    For some reason I cannot capture any video. My controls do not seem to be working in Premiere.
    I am using:
    Premiere Pro 1.0
    DVStorm2 Pro
    Canon XL-1
    In the past I have successfully captured DV footage using either in/out points or batch capturing. Today, however, I can’t get it to work. I forget what order I should use when opening Premeier and turning on my camcorder.
    I am using the “Canopus DV Device Control” in the Device Control window.
    I am using the “Canopus DV Capture” in the Capture Settings window.
    Input Channel is “DV1”
    Any suggestions would be appreciated.
    Kurt
    Scott replied 21 years, 5 months ago 2 Members · 2 Replies
  • Kurt Raihn
    April 5, 2005 at 1:29 am
    After messing around for 1/2 and hour I did what I should have done much earlier, that is, to shut down my computer and reboot.
    Problem solved. Guess I am not going crazy.
    Kurt
  • Scott
    April 5, 2005 at 1:55 am
    Reboot – The new “size 12 matinance”
