Activity Forums Adobe Premiere Pro need help achieving two effects framing and collage
  • need help achieving two effects framing and collage
    Posted by Carla Cameron on August 8, 2008 at 3:49 am
    Hello,
    I am editing with CS3. How do you get the effect where the video clip looks like it is in a frame with the animation around it? Do I need to create the animation in AE and then in Premier add a reduced-sized video on another track below the animated track?
    And how do you add several reduced-in-size video clips to the screen and have them all stay there? It is like making a collage. I tried using PIP but that didn’t work. The images fly off the screen. I want the video clips to fly on to the screen and remain their until the whole screen is full.
    Is there a website where I can find out how to create these effects?
    Thank you in advance for your response.
    Carla
    Jon Barrie replied 18 years, 1 month ago 3 Members · 2 Replies
  • Vince Becquiot
    August 8, 2008 at 11:19 pm
    You simply need to scale the clips down. In the efects panel, use the motion settings.
    Vince
  • Jon Barrie
    August 9, 2008 at 1:33 am
    you need to animate the scaled down clips position to have them enter the frame, then don’t add anymore animation keyframes. they will stay in the position last keyframed.
    – Jon 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
