  • Posted by Neil Jay on February 26, 2007 at 8:38 pm
    Hi, I shot HDV footage with my Sony FX1 and captured it into FCP with easy setup at 1080i60. After I edited the footage in the timeline, I wanted to convert the movie to SD and burn it to a DVD. I was told to export using compressor at settings of DVD Best Quality 90 minutes. I did this and loaded it into DVD studio pro. When I burned the DVD it came out very choppy as if it were skipping. Does anyone know what went wrong or what the correct procedure would be?
    Neil
    Mark Maness replied 19 years, 5 months ago 2 Members · 3 Replies
  • Mark Maness
    February 26, 2007 at 9:55 pm
    Have you rendered the entire timeline before you exported to DVDSP?
    Did you adjust any of the settings in Compressor?
    From what you say, it sounds like the KB rate was too high for playback.
    How long is your project?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Neil Jay
    February 26, 2007 at 11:59 pm
    I did render and I did not change the kb rate or any other settings.
    Neil
  • Mark Maness
    February 27, 2007 at 4:38 pm
    Ok…
    Try this…
    Export your program into a single Quicktime file. Then import this file into DVDSP. DVDSP can encode also… Its not the best but it does work ok.
    Wayne Carey
    Schazam Productions
