Activity Forums Apple Final Cut Pro Legacy Need HDV to h264 standard def 16:9 export path
  • Need HDV to h264 standard def 16:9 export path
    Posted by David42 on April 20, 2006 at 2:53 am
    I have been experimenting with exporting H264 from an HDV project. I want to make standard def (720 x 480) movies, but can’t find the 16:9 setting. What am I missing?
    Also, I notice that there are no H264 settings for Compressor.
    I am running FC Studio 5.04 from a G5/2ghz, OS10.4.5
    Thx
    David42 replied 20 years, 5 months ago 2 Members · 2 Replies
  • Walter Biscardi
    April 20, 2006 at 3:00 am
    [David42] “Also, I notice that there are no H264 settings for Compressor.”
    Sure there are, they’re the Quicktime 7 exports for the Web settings. Simply go into the Aspect ratio after you set the H.264 codec and manually set it to 16:9 to keep it in widescreen.
    I do this all the time for uploads
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • David42
    April 20, 2006 at 9:50 pm
    Thx for the reply Walter. Always helpful to know that a path exists.
    As you suggested, I drilled thru the Compressor 2 Web QT7 settings to H264 for streaming/downloading.
    None of the presets I see fits my requirement for SD full raster, 720×480. The largest, LAN streaming, is 640×480
    I don’t find an H264 aspect control in either Compressor, or the FC export settings.
    A possible related issue is that my QT7 is not upgraded to Quicktime Pro, although the install documentation says it should have occurred automatically with the FC Studio upgrade
    While I chase QT7Pro with a re-install and/or custimer support, does any of this above help you help me?
    Thx
