Activity Forums Apple Final Cut Pro Legacy Need hardware advice please
  • Need hardware advice please
    Posted by Roli Rivelino on February 28, 2009 at 5:56 pm
    I’m almost finished setting up my system, but I want to change my seagate usb 2 external hd for a firewire 800 1TB drive.
    Just wondering if anyone can give me some advice as to which drive to get and where to get it?
    I’m based in the UK, so UK companies or at least ones who deliver swiftly to the UK would be preferable.
    Many thanks
    Roli Rivelino replied 17 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Ernie Santella
    February 28, 2009 at 6:10 pm
    Do a search on the topic. It’s been discussed many times in detail. Plus, you didn’t give any details of what you are doing and on what equipment?
    HDV? SD? Uncompressed HD etc? Tower or Laptop? First off, FW800 is pretty limited for editing, especially with HD. Do some research into Fiber, eSATA etc. for faster Raid storage.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • Roli Rivelino
    February 28, 2009 at 6:21 pm
    Sorry I did try a search but couldn’t find a relevant post, I’m getting a;
    Mac pro, single quad core 2.8ghz processor, 1x320gb 7200 hard drive 1x1TB 7200 hard drive Geforce 8800 512mb graphics card,
    I will mainly be editing HD but will also be doing some DV
  • Ernie Santella
    February 28, 2009 at 6:46 pm
    Still lots of questions. There are so many different types of ‘HD’. Formats like HDV are highly compressed all the way to Uncompressed 1080p which would require an extremely fast RAID.
    Here’s a few links to read.
    https://forums.creativecow.net/thread/8/977568
    https://forums.creativecow.net/readpost/8/1022850
    https://forums.creativecow.net/readpost/8/1021735
    Just use the search function and search ‘RAID’ ‘Storage’ etc. I found these links in minutes. Good Luck. We’ll all help, but it sounds like you don’t completely understand what the differences are yet.
    Ernie Santella
  • Alex Elkins
    February 28, 2009 at 8:03 pm
    Check out http://www.eclipsecomputers.com in Coventry, UK for some good prices and selection on harddrives.
    I would recommend Seagate Barracuda or Hitachi Ultrastar drives. Both of these drives come as ‘stand-alone’, i.e. not inside an external enclosure.
    You can get Seagate and Western Digital FW800 pre-built external drives, but personally I would buy a SATA harddrive and an e-SATA enclosure and just make it myself. It’s straight-forward, and SATA is much faster than FW800. You’d also need an e-SATA PCI card, which are about £15 for a bog-standard one (what I use on my G5 at home). Works fine and anyone in a computer shop would be able to help if you weren’t sure about it.
    Good luck,
    Alex
  • Roli Rivelino
    March 2, 2009 at 11:26 am
    OK thanks Alex, I’ve found the Seagate 1000Gb FreeAgent Pro External eSATA,USB,FW Drive at the site you gave me.
    I’m still a bit in the dark about this eSATA business, I’m just wondering if this is the right hard drive to go for and if I’ll still need an eSATA card with it?
    This is the product link to the drive if you need to check https://www.eclipsecomputers.com/product.aspx?code=HES-1000FPEUF
    Many thanks
  • Alex Elkins
    March 2, 2009 at 2:31 pm
    Hi Roli,
    That drive is pretty good, we use them in our office. You don’t need any additional cards to use it, as your computer has Firewire built in – however, for an extra £15 I’d personally be wanting to get the e-SATA card too, because it’ll be a hell of a lot faster than FW400. Note that is is FW400, not FW800 which is what you said you wanted in your first post. (Don’t forget to buy an e-SATA to e-SATA cable too if you go for the card, as I don’t think they come with the harddrive.)
    Good luck,
    Alex
  • Roli Rivelino
    March 3, 2009 at 9:41 am
    Once again, thanks Alex, I’m getting the Lacie pc card and I’ll make sure to get the cable as well.
