Activity Forums Adobe After Effects Need Guidance with the Project
  • Need Guidance with the Project
    Posted by Anvay Nakade on May 30, 2011 at 9:26 am
    Hi everybody.My first post.
    I need some guidance in conceiving the idea that I have in mind.
    my idea is to create a composition where there are a series of photos and they start to play in a zoom out fashion and continues until the final picture comes out of the eye of the person.Sort of the vision of a person.
    How to go about this in after effects?
    Anvay.
    Charlie Davies replied 15 years, 3 months ago 3 Members · 2 Replies
  • Jason Mettler
    May 30, 2011 at 5:36 pm
    That will be relatively easy in AE. Pre-comp your pictures and set up the move you want in Z-space. Then copy the keyframes to all the other pic comps and offset them according to taste/time. The last pic to move out of the eye you can fade out the transparency or zoom out to nothing over the face as you pull back. I might animate all the pictures to do the moving but, then, do a camera pull for the the face shot (and add in some depth of field).
  • Charlie Davies
    June 3, 2011 at 8:59 am
    That move is covered in this tutorial, will just need a bit of tweaking https://www.videocopilot.net/tutorials/earth_zoom/
