Activity › Forums › DVD Authoring › need good dvd burning software -Toast sucks
  • need good dvd burning software -Toast sucks
    Posted by Russ Spencer on April 11, 2010 at 8:56 pm
    I am a filmmaker and had been using Toast 6 for years to burn DVDs from Video TS files. Fine.
    Installed Snow Leopard and Toast 6 stopped working. Fine.
    Spent $100 on Toast 10 Titanium. Fine
    Toast Titanium has every bell and whistle you can possibly imagine, but it cannot burn a DVD. Not so fine. It does not calibrate the blank disc capacity correctly. It says there are only 4.3 gigs on a single layer disk that really has 4.7 and 5.7 on a dual layer which really has 8.5. Roxio tech support has been completely worthless. Downloaded update from version tracker, did not fix problem.
    On deadline and need to find a burning solution that actually works. Suggestions?
    Wesley Kirk replied 14 years, 7 months ago 3 Members · 2 Replies
  • Michael Sacci
    April 12, 2010 at 12:33 am
    Most software that you author DVDs with can burn the disc.
    But the sizes are correct, just a different way of describing it. 4.3 for a 4.7 and 7.5 for 8.5 is correct.
    So if you do a get info in the finder on the video ts folder and it tells you it is 4.5GB it will not fit on a DVD-R.
  • Wesley Kirk
    February 17, 2012 at 3:13 am
    I waste more blank DVDs trying Toast Titanium 10 than I can afford. A waste of over 100$.
    I do all my DVD work on my Virtual Machine, Parallels. I use DvdFlick, a free program to convert videos to TS folders, and then Total Media Extreme which I got when I bought an external Memorex DVD player. This combination never fails.
