Activity › Forums › Apple Final Cut Pro Legacy › Need eSata card for my Mac Pro
Posted by David Ornowski on March 16, 2008 at 7:39 pmI just bought a new Mac Pro, and would like to install an adapter card to allow me to attach an external sata raid. I found this at FirmTek:
https://firmtek.stores.yahoo.net/sata2es2e.htmlI am hoping someone out there can confirm that this is a good solution for what I want to do. Thanks!
Dave Ornowski
David Ornowski replied 18 years, 6 months ago 5 Members · 7 Replies -
Arnie Schlissel
March 16, 2008 at 8:54 pmIt’s impossible to say without knowing mare about what you want to do.
What enclosure do you want to connect it to? How many drives do you want to support? Do you need any kind of RAID protection (RAID 1, 3, 5 or 6)?
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
David Ornowski
March 16, 2008 at 9:22 pmI have 2-1TB Satamax arrays from Promax (raid 0, I believe), that I use with my FCP Pro system at the office. I would like to be able to take these drives home on occasion, and edit with them on the new Mac Pro. I’m hoping all I need to do is pop the adapter into the PCIe slot, plug in the arrays, and be ready to go.
Arnie Schlissel
March 16, 2008 at 9:41 pmThe simplest thing to do is to call Promax & ask them what’s compatible.
Arnie
Bob Zelin
March 16, 2008 at 10:29 pmArnie is correct – call ProMax. I believe that up until recently, ProMax was using the Cal Digit SATA card. Firmtek is an excellent company. But there are port multipler chassis, and single drive chassis – there is SATA (SATA I) and eSATA (Sata II). You don’t want to purchase something, and have it not work.
Bob Zelin
Zane Barker
March 16, 2008 at 10:57 pmMacPro Towers have 2 additional sata ports inside the computer all you will need is this.
https://eshop.macsales.com/item/Newer%20Technology/MPQXES2/
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Sean Oneil
March 16, 2008 at 11:38 pm[Zane Barker] “MacPro Towers have 2 additional sata ports inside the computer all you will need is this.”
Just a warning, that solution won’t always work. The Mac Pro’s SATA ports don’t play nice with SATA-I disks. And they don’t support hot-swapping or port multipliers.
I like the Highpoint cards because while they are priced similarly to Sonnet and Firmtek, most of the Highpoint cards support RAID-5.
Sean
David Ornowski
March 17, 2008 at 2:15 amThanks for all the responses. I agree the wise thing to do is to give Promax a call. Really the only way to be sure I’m getting the right thing. Thanks again!
Dave
