Activity Forums Adobe Premiere Pro Need decoder for importing Premiere Pro into Encore
  • Need decoder for importing Premiere Pro into Encore
    Posted by Contrain on March 28, 2007 at 3:18 am
    I use Premiere Pro 2.0 and Encore 2.0, when I try to import a Premiere Pro movie into Encore to make a DVD I get the error message:”The Software that’s used to decode the media is not available on this system installing the correct decoders for the files you are working with may help to correct the problem”
    How do I get the decoders to work with this?
    Steven L. gotz replied 19 years, 6 months ago 4 Members · 4 Replies
  • Vince Becquiot
    March 28, 2007 at 3:23 am
    What Codec are you using to export from Premiere ?
    The only real options, if you want a “quality” DVD, is exporting uncompressed, or Mpeg2-DVD using Premiere Media Encoder.
    Mpeg2 is the most efficient way, since it will only require one render. The video size also needs to 720×480/486 for NTSC.
    Vince
  • Contrain
    March 28, 2007 at 4:24 am
    Does this mean I’ll have to use the Encoder in Premiere 1st, then output as an MPEG-2 then import the MPEG-2 file into Encore for this to work?
  • Mike Velte
    March 28, 2007 at 11:44 am
    [contrain] “Does this mean I’ll have to use the Encoder in Premiere 1st, then output as an MPEG-2 then import the MPEG-2 file into Encore for this to work?”
    This is the normal workflow.
  • Steven L. gotz
    March 28, 2007 at 2:55 pm
    Or export as DV AVI and use that file in Encore.
    Steven
    https://www.stevengotz.com
